Need Help For Creating a Space Truss
abdul_alim
abdul_alim
Hello Guys,
I'm New To Revit Structure/Architecture I want to Create A Space Truss, as per the 2D Drawing Attached,
we already Created one Though Plane Based family, as per Revit Snap Shot Attached Below,
as seen in the 2D drawings, Bracing Members are not at same angle in every Instances, And we need to Create Space Truss in Such a Way that , in future we can Easily Create a Schedule out of it.
@sureshchotrani
sureshchotrani
@abdul_alim Kindly share the DWG via PM.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
abdul_alim
Please find the attachment for the Pan view and Section Views .dwg of Critical Area Only, Which I Found Difficult to model.
abdul_alim
Solution Found,
Ok Guys, Solution Found, Made a Space Trusses as per the Desired Angle, Through The Generic Family Only, Then Only it will be usable in Future For Quantity Take.
handjonathan
Nice work @abdul_alim Thanks for following up and sharing the workflow
Jonathan Hand
Technical Marketing Manager | Construction
