Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Weekly New Knowledge Articles by Support team | Mar 8 - 14th, 2023
0 REPLIES 0
Message 1 of 1
lim.wendy
74 Views, 0 Replies
Our Revit support team has created knowledge articles for you to address the issue on your own. Several incidents have been reported, so be sure to review them for potential workarounds.
Published Date
Summary
Knowledge Article
Incident Logged
14-Mar-23
A space is not visible in floor plans but is visible in the schedule in Revit
No
13-Mar-23
"This field cannot be blank. Enter text to continue." message when trying to map parameters in families in Revit.
"This field cannot be blank. Enter text to continue." message when trying to associate parameters in...
No
13-Mar-23
Users reported that Structural Framing position is incorrect after changing height type property in Revit.
Structural framing behaves incorrectly when editing its height in Revit
Yes
11-Mar-23
Model is shown on screen and status bar says "Ready", however the "Open Model" dialog box shows no progress on bars and is unresponsive.
Unable to fully open a Revit Cloud Worksharing model
No
10-Mar-23
It is impossible to export IFC when "Building Story" level parameter is active in Revit.
Cannot export IFC when "Building Story" level parameter is active in Revit
No
10-Mar-23
Keynote tags move after sync with central and re-opening in Revit
Yes
10-Mar-23
Users have reported that when using the 'Filter by Sheet' option on a Note Block Schedule, the view template for the schedule gets overridden.
Note Block Schedule view template overridden when using 'Filter by Sheet'
Yes
10-Mar-23
Wrong distance between Fabrication items in Revit
Unexpected distance value between Fabrication items in Revit
No
9-Mar-23
Users reported that they cannot map IfcPredefinedType for Structural Rebars (IfcReinforcingBar) when linking IFC in Revit.
Cannot map IfcPredefinedType for Structural Rebars (IfcReinforcingBar) when linking IFC in Revit
Yes
9-Mar-23
Is it possible to modify the unit setting for levels in Revit?
How to change the unit for levels in Revit
No
9-Mar-23
How to view a model created in a previous Revit version without needing to upgrade it.
How to view a model created in a previous Revit version without upgrading it
No
9-Mar-23
When creating a Model In-Place component, after selecting the category and clicking OK, the model disappears in Revit.
Model disappears from view when using the Model In Place command in Revit
No
9-Mar-23
Users reported that when inserting components, not with the same sequence as the P&ID schema in Revit the following message appears:'Some of the connected objects no longer match their P&ID location[...]'.
'Some of the connected objects no longer match their P&ID location [..]' when inserting components i...
Yes
9-Mar-23
When working with Revit Windows sporadically crashes with a Blue Screen on a specific machine.
Sporadic Blue Screen crash of Windows when working with Revit
No
9-Mar-23
Texts in schedules (Schedule Graphics) are not exported correctly into DWG from Revit.
Text in schedule is not exported correctly into DWG from Revit
Yes
9-Mar-23
Users reported that it is not possible to export insulation as IfcCoveringType with predefined type WRAPPING using IfcExportAs from Revit
Unable to export insulation as IfcCoveringType with predefined type WRAPPING using IfcExportAs from ...
No
8-Mar-23
"System.ArgumentException: An item with the same key has already been added..." when starting Dynamo in Revit
"System.ArgumentException: An item with the same key has already been added..." when launching Dynam...
No
8-Mar-23
What is the possibility of loading and editing an IFC model in Revit?
Load and edit possibility of an IFC model in Revit
No
8-Mar-23
When selecting walls in a particular Revit project, the graphic display is incorrect. The location line unexpectedly displays outside of the wall.
Misplaced wall location line in Revit
No
8-Mar-23
Placing Rebar on slopping floors does not work in Revit.
Yes
8-Mar-23
How to use Revit with Digital Twins?
Revit and Digital Twins
No
8-Mar-23
Special characters do not export to PDF as expected in Revit
Yes
8-Mar-23
Where to find useful add-ins for Revit?
Where to find add-ins for Revit
No
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Customer Value Hub
0 REPLIES 0
Forma Design Contest
