Our Revit support team has created knowledge articles for you to address the issue on your own. Several incidents have been reported, so be sure to review them for potential workarounds.
Published Date |
Summary |
Knowledge Article |
Incident Logged |
25-Mar-23 |
Connections get created on opposite column side in Revit when import SMLX file from Advance Steel |
Connections imported on opposite side in Revit from Advance Steel |
Yes |
25-Mar-23 |
Elevations and sections with irregular crop regions are incorrectly mirrored after using the Mirror Project tool in Revit |
Some elevation and section crop regions are mirrored incorrectly after mirroring project in Revit |
No |
24-Mar-23 |
Users reported that it is not possible to set the Heat Transfer Coefficient value to the required one in Revit |
Cannot set the Heat Transfer Coefficient value to the required value in Revit |
Yes |
24-Mar-23 |
Users reported that custom roof parameters not exported to IFC from Revit |
Yes |
24-Mar-23 |
Users reported that pipes from linked IFC model are located far outside from model in Revit |
Yes |
24-Mar-23 |
When powering electrical devices in Revit, the Space Name and Number are not automatically added into the Load Name of the created circuit. |
Space information not associated with Load Name automatically in Revit |
Yes |
24-Mar-23 |
Render in Cloud button is missing in Revit LT |
No |
23-Mar-23 |
Dynamo starts very slow in a non-internet environment for Revit 2023 |
Yes |
23-Mar-23 |
Is it possible to convert a Revit Family file (RFA) to a STereoLithography (STL) file? |
How to convert a Revit Family file (RFA) to a STereoLithography (STL) file? |
No |
22-Mar-23 |
How to optimize the positioning of elements through Dynamo in Revit? |
How to optimize the positioning of elements through Dynamo in Revit |
No |
22-Mar-23 |
Revit closes unexpectedly when working with MEP models. |
No |
21-Mar-23 |
How to control the visibility of nested point cloud files in linked cloud models in Revit? |
How to control the visibility of nested point cloud files in linked cloud models in Revit |
No |
21-Mar-23 |
When importing in Revit a SMLX file exported from Advance Steel model, most elements are missing. Only some grids are visible |
No |
21-Mar-23 |
Users reported that nothing is displayed after IFC import in Revit |
Yes |
21-Mar-23 |
When opening a model in Revit, the process hangs at loading linked Structural models and never completes. |
Revit hangs during the opening process when loading a Structural model and never completes |
No |
21-Mar-23 |
When the size of the pipeline changes from larger to smaller, gaps are created between the fittings and the pipes. |
Yes |
20-Mar-23 |
Users reported that opening IFC file exported from Archicad-26 is not possible in Revit. |
"Cannot open filename.ifc" when importing IFC from Archicad-26 in Revit. |
Yes |
20-Mar-23 |
Revit creates an additionally center line between connector in a duct fitting multi port family. |
An extra center line is automatically created that extends beyond the family instance in Revit |
Yes |
20-Mar-23 |
Users reported that user defined property set related to IfcProject properties is missing in exported IFC from Revit |
Missing property set related to IfcProject properties in exported IFC from Revit |
Yes |
