want to clip view of linked file
ewijnen
Message 1 of 8
ewijnen
Dear all,
Is it possible to only see a part of a linked file: In a project of a office building I have linked a file that shows the installations of the whole building. I am working on a specifik module and only want to see the installation around that area. Can I "clip" what part I want to see of the linked file and exclude the rest? (I know you can clip xrefs in autocad, I hope I can do the same here).
Thnx!
Esther
Replies (7)
Message 2 of 8
hmunsell
couple options....
  • Use a named Scope Box around only the content you want to see and assign it it to your view(s)
  • Use the Crop View option in your view(s)
  • Use a Selection Box and adjust the box around the content you want to see
    • you will have to select the box and Hide in View once you have it where you want
Howard Munsell
Message 3 of 8
Turn off link in the main view. Create another view with only link and crop it. Place them both on sheet.
Message 4 of 8
ewijnen
Thanks for the fast reply
But I need it when working in 3D views or working in the model. Not for final sheets or prints.
So more like a "section box" specifik for the linked file.
Message 5 of 8
ewijnen
Hi thank you, but this is for 2D views if I am correct? I am looking for a scope box for 3D views. I am fairly new in Revit so correct me if I'm wrong =).
Message 6 of 8
hmunsell
Named Scope boxes are 3D elements and can be used in 2d or 3D views.
Howard Munsell
Message 7 of 8
ewijnen
THank you for the suggestions but this is not giving what I am looking for unfortunately:
- the selection box crops everything wich I do not want. (I want to crop only IFC's, not entire model)
- crop view ditto problem
- I can not select an IFC to add to a workset for a section box? (I might be doing something wrong)
Message 8 of 8
hmunsell
Hmmmmm... I'm not aware of a way in Revit to only clip one link and not others. all the ways I know are pretty much an all or nothing.
Howard Munsell
