Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Visibility and reinforcing mesh question.
11 REPLIES 11
Message 1 of 12
jize.liu
663 Views, 11 Replies
jize.liu
Hi everybody, I am not sure how to deal with this issue, I hope some brilliant minds can help me here.
Please see the screenshot below. (This is part of NU Girder)
The bottom green and sky blue rebars are custom made mesh (see screenshot above for mesh detail). Made by 2 different sizes of MD bars. Each piece of mesh is over lap to cover the entire girder.
Even if each mesh is made of many bars, it still needs to be considered as one piece.  I decided to approach this by making the mesh as a generic family. Also base on the very limit knowledge I have for the Revit. I don't think it's feasible to do it by using revit  rebar tool.
Here is the problem, when I switch the visual style to non wireframe. ALL the mesh is no longer visible to me.
How do I overwrite this or should I create the mesh in a different way.
11 REPLIES 11
Message 2 of 12
jay_colcombe
in reply to: jize.liu
jay_colcombe
You can edit sheet reinforcement as per the following advice.
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-098B9B94-B06D-4455-BDA6-182AB2E1ECEA
As regards drawing this in Revit using Rebar that would be feasible just cut a section and draw the coat hanger shape and add a spacing value so it distributes along the length of the host and then place longitudinal bars for the hanger support bars, again in the section
Jay Colcombe
Autodesk Certified Instructor
Jay Colcombe
Message 3 of 12
ovidiu_paunescu
ovidiu_paunescu
Hi @jize.liu
You could try to model that using a bent fabric sheet
https://youtu.be/fb0CKNGTRGk
For your example it could look like this
To sketch this, go to Structure tab > Reinforcement panel and click Fabric Sheet
Then in the Modify | Place Fabric Sheet ribbon click Bend Sketch
Sketch the shape
In the type properties you can find an overhang property. You can use this to define the length by which the longitudinal bars overlap the next segment.
In the properties palette there is a parameter for defining the longitudinal cut length.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Hi @jize.liu
Sketch the shape
Message 4 of 12
jay_colcombe
jay_colcombe
If you do use the Fabric Sheet > Bent Sketch method
In Revit 2021 you have the option for Bent Fabric sheets in View Visibility as you would with Standard Rebar so seems it would cover all your questions.
This is also the case in Revit Revit 2024
And you can turn the Boundary off via Visibly Graphics in
Jay Colcombe
Jay Colcombe
Message 5 of 12
jize.liu
jize.liu
Thanks guys. I appreciate all the detail information and screenshot.
Sorry I have a follow up question. If I use Fabric sheet tool:
  1. can I add new wire type?
  2. how to control the wire spacing? This is custom made mesh(for example: 11 SP @ 75MM then switch to 4 sp @ 100mm. )
Message 6 of 12
jize.liu
in reply to: ovidiu_paunescu
jize.liu
Message 7 of 12
jay_colcombe
jay_colcombe
you can create you own Mesh/Fabric sheet
In the Project Browser > Families >  find a sheet close to your specification > Right Click > Duplicate > Type Properties and edit the Parameters specific for your needs
You can use the Precast Tools to create you own Custom Fabric Sheet if this is not satisfactory
Help | Create and Edit Custom Fabric Reinforcement Sheets | Autodesk
Jay Colcombe
Jay Colcombe
Message 8 of 12
jize.liu
in reply to: jay_colcombe
jize.liu
Sorry I think I am been very challenging to you . I see there are a lot to learn. So I decide to try custom fabric sheet. I use rebars tool drawing the rebars and placing it at the right spacing. I assembled all the rebars and then click the custom fabric sheet button. I got a error message.
Message 9 of 12
jay_colcombe
jay_colcombe
As the message the Precast method will only allow this in a single host can you confirm the rebar is fully contained within a single slab or wall?
As regards the custom Fabric Sheet, are you stating the bars change diameter and spacing in the same direction?
If it is regular spacing in the X direction and the regular in the Y this is achievable by duplicate a standard sheet even with different bar diameters and spacings in the X&Y
Jay Colcombe
Jay Colcombe
Message 10 of 12
jize.liu
jize.liu
Thank you for your help.
For mesh information please see screenshot below
As you can see, 2 type of MD bars (Horz. & vertic.)  with different spacing.
For the Precast method, It's generic models family I made, shape as a NU girder, not walls or slabs. If my understanding is correct, i drawing the rebar inside the girder, so I think they are  fully contained. (visually )
Message 11 of 12
jay_colcombe
jay_colcombe
I think you are outside the limits of the software but happy to be proven wrong.
i would approach it using standard bars and and shapes and create a sheet using single bars then create a Group or Assembly and use the sheet reference as the name so you can count the numbers used and then manually place or copy the Groups/assemblies along the elements/hosts!
Hopefully the Revit Gurus can find a better way of achieving your requirements.
Jay Colcombe
Jay Colcombe
Message 12 of 12
jize.liu
jize.liu
I will mark this as "answered" even we don't have one yet, it's seems like this is a important thing in this planform.
Also huge thanks for your patience to explain everything to me. At least I learned stuff. Thanks for your help,  I can create and add my own wires bars in the system now.
I already tried "group" or " Assembly" tools
For Assembly : I am use assembly tool to create shop drawings. so my box girder with all the components are already one assembly. It's seem like a assemblies can't nest or contain one another. so If I assemble all the rebars that mean these rebars will not show in my box girder assembly view.
For Group : It seems like I can include the rebars group in a girder assembly. However, in the assembly view, all the rebars show as ungrouped somehow...but same bars show as grouped in the structural plans view. Also rebar schedule will not count per group only per each girder assembly .
The mesh tools / custom fabric sheet are already build in the programs. Let's hope one day they can enhance it.
