Viewport Size on Sheet
How do you resize this?  I placed it on a sheet from a scope box?  There has to be a simple solution.
Mohamed-Nassar
From Crop region visible you can control this line to make them all in the view of sheet
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
alan_eu
Hi @Anonymous
I really prefer to use a scope box to modify all the view limits just one time. This way is easier to control every view printable area and drag it to your sheets 🙂
gG4kgZX
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
Jason.P
Have you tried unchecking your crop region visibility.
Jason Peters
BIM Manager
Autodesk Expert Elite Alumni
Thank you for everyone's suggestions and help.  Turned out that there were two scope boxes named very similar to each other.
Jason.P
that is tough when that happens. Sometimes it is the littlest thing. I try to instill on my team to make sure when then name things, regardless of it being a section, scope box, reference plane etc etc, to make it clear and understandable to who ever works in your model. You may name something and at the time it makes sense to you, but 3 months from now are you or another user going to know what it stands for. It takes a bit of time to get used to but good naming practice is key.
Jason Peters
BIM Manager
