Stair Path Arrow
Stair Path Arrow
Stair Path Arrow
Does anyone have any idea why this stair path arrow is continuing past the break line?  I have all <Above> graphics for the stair turned off, yet this arrow is still showing when I want it to stop at the break line.
Thanks in advance!
Jamhmer_Oc
Hi @Anonymous
Try this.
Enter graphics visibility (VG) > Annotation Categories and deactivate Up arrows.
Jamhmer Oc
alan_eu
Hey again, @Anonymous
Select you stair, Edit type and change this cut mark Type guy here to none.
70lxWsu
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
Thanks for your reply - One thing I should have mentioned is that the stair in my plan view is directly from a linked architectural model.  When I add the "stair path" annotation, it shows the arrow continuing up like my screen shot.
I ended up just copying in the stairs from the arch model and adding the stair path as normal where it finally displayed as normal.
alan_eu
Many things on stairs has changed at 2015 (?). If your template is older than that could restrain some different configurations, so, it´s nice to remake your Template each 3 or 4 yrs 🙂
Hi there,
I have the same problem, I'm trying to annotate the stairs path in a linked model (a model just for annotations, stair are modeled in a different model) and the  path show two arrows and non continuous line.  It is a way around instead of copying the stairs? were you able to applied the suggestions of changing cutline type and view template?
