Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
view rebar as solid in 3d view
2 REPLIES 2
robertawalker
204 Views, 2 Replies
I am using Revit 2024.2. I am trying to show rebar as solid in a 3D view. I have read many posts on how to do this but when i select view visibility states for the element i get the option to view unobscured but i do not get the option to view as solid. Has this option been removed in Revit 2024.
2 REPLIES 2
I have found part of the answer, the detail level of the elements in the view was set to medium. I reset that to by view and it does now show the rebar as solid. Having said that there is still no option in the view visibility states to view as solid.
Tom_Kunsman
in reply to: robertawalker
Has not been removed -
