I am using Revit 2024.2. I am trying to show rebar as solid in a 3D view. I have read many posts on how to do this but when i select view visibility states for the element i get the option to view unobscured but i do not get the option to view as solid. Has this option been removed in Revit 2024.
Solved by robertawalker. Go to Solution.
I have found part of the answer, the detail level of the elements in the view was set to medium. I reset that to by view and it does now show the rebar as solid. Having said that there is still no option in the view visibility states to view as solid.
Has not been removed -
