Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
View range
2 REPLIES 2
rimutaka
1957 Views, 2 Replies
View range
I design a building which has different roof ridge elevations.
What is the best way to set up a “view range” hence I can see all components of the roof e.g rafters, purlins etc?
2 REPLIES 2
ennujozlagam
in reply to: rimutaka
hello, you can try hide in view. thanks
If your structural plan view is looking down then you can use Plan Regions for different View Ranges.  If the view is looking up then it may be more complicated, because View Regions don't work well looking up.
Forma Design Contest
