Variable Rebar at Stair out of limit
rafael.marinGFHRP
rafael.marinGFHRP
i created this variable rebar but at red you can see it goes off the stair, how to fix it
Replies (11)
rafael.marinGFHRP
even changing ALL point restrictions, it still super out of the stair...
s.iwasakiSYTFM
Is this document not helpful?
I thought page 21 might be helpful.
https://static.au-uw2-prd.autodesk.com/FAB322472-L_Class_Handout_FAB322472L_Ovidiu_Paunescu.pdf
Please click the Accept Solution button if my reply answers your question.
こちらの投稿は役に立ちましたか?良ければ「いいね」お願い致します!
こちらの投稿があなたの問題解決に寄与した場合、「解決策として承認」ボタンのクリックへのご協力をお願い致します。
Satoshi Iwasaki
ONESTRUCTION Inc.
rafael.marinGFHRP
i tried, but all the posibilites of initial and end surfaces i could try it always get  5 different types of error
jay_colcombe
This may be due to too many different non-planar faces so cannot be controlled correctly!
In this instance I would recommend using Free-Form rebar as it’s easier to pick the faces and path
Jay Colcombe
Autodesk Certified Instructor
rafael.marinGFHRP
I see, but im afraid i couldn't apply this free form rebar at this just one stair step, i tried following autodesk guide but it appears 5 different errors while trying to create the rebar
jay_colcombe
its not ideal but a common workaround is to model the Step as an In-Place Family as a Generic Model that can host rebar and then apply the Free-Form to this and then hide it to only show the rebar
Jay Colcombe
rafael.marinGFHRP
i will try
rafael.marinGFHRP
The free form rebar can't do the shape  as i needed, also i tried doing the same rebar but normal on the generic model i reated of the step
rafael.marinGFHRP
sadly free form rebar dont work well at models that shapes are very different, like stair steps
jay_colcombe
I am back at a PC not so taken a look, Varying does not like more than one Face/Edge you can split the rebar down into to individual sets - in the example below i create the 3 bars as standard to the Flat Face then Copied them to the side and set these to Varying and dragged the grips to align to other bars and faces
You can also align them to each other and untick the Remove Edge Bar option to avoid double counting where they overlap
You can also use Varying Rebar and Edit constrains for the Edge Reba link to the downstand/riser
Jay Colcombe
rafael.marinGFHRP
making more than 1 rebar its the way to it, worked here! thanks, altought its more complicated when there is a lot of different steps, like on the "fan" type of stair, so a lot of work but thats the way. thanks!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
