Using the match properties tool
Hello everyone,
I am recently trying to learn to work with Revit structures, and I am wondering how does the match properties tool function in Revit. I think that you will get better what I am trying to explain through this picture. In this image you will see 3 piles, the first one has a different length in comparison with the others, and i would like to know if with match properties the length of the first pile can be adopted into the other ones. The image that shows this is Secção A_1.
ennujozlagam
Hello, I guess it is not possible only apply to type, text etc.. You can try pick the objects right click to your mouse and choose create similar. thanks
jbrazier
Element length is typically not a property that can be "Matched".  For the most part "Match Properties" matches element Type.
Jon Brazier
Director of Production Technology
O'Donnell & Naccarato
Philadelphia, Pa.
