Error when trying to change the level offset distance
Hello everyone,
I am at the moment working in Revit Structure 2018. The project that I am currently modelling are indirect foundations made with piles. The error that I am obtaining is the one that you can check at the picture named: Changing levels.
Also, since the bedrock is not at the same distance from the level that is correspondent to the base level, the length of the piles are going to be variable. Given this situation, one of the ideas that I had to model this situation was to make various cuts through the all project, each one of them represent different lengths, and what I am trying to do is to create in each of this sections views different base levels to the piles, or in other words, different offset levels from the base and I dont know if this is possible or not.
best regards
Avaris.
Yes it is possible, it only warns you that they will be invisible in that view. If they were visible before I would suggest to adjust your viewrange.
