Show only
Search instead for
I have a design model that is drawn in the architecture template of revit 2013. Do I draw the columns and beams in the structure template or continue to draw in the architecture template? If I have to draw it in the structure template, do I have to use revit link to link my model into the structure template?
The answer depends on what you are trying to do. If you are going to create a Structural model, then I would start with a Structural template - link in your Design model, then add your Structural elements over this.
