Hi @kenneth.hestholm,
It is possible to have customized schedules in the shop drawing. To achieve this you need to perform the following steps:
Step 1: Go to Schedule Template.rte - this is found C:\ProgramData\Autodesk\Structural Precast for Revit 2019\Families\en
- Add and customize any schedule that you need to be added in the shop drawing;
- Add a name for the schedule (is important to use this name in the next step);
Step 2: Go to Schedule.rfa and add new type of schedule.
- Add new type and make sure to use the actual name of the schedule defined at step 1 for the Template Schedule field;
Step 3: RE-load the schedule.rfa in your titleblock or create a new one by following these steps:
http://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-47432AE7-497B-481F-8DA2-860B2F89BD07
Kind regards,
Bogdan Teodorescu
Product Owner
