Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
unhide category not activated
4 REPLIES 4
A_MAQ
386 Views, 4 Replies
hello,
i have imported cad , but it does not appear in view
i have checked the reveal button and i found it , but i could not make unhide for cad
what is the solution for this situation?
thanks
Autodesk Expert Elite
4 REPLIES 4
bjoern_teutriene
in reply to: A_MAQ
Hey,
Either your import or your view settings are not correct. When linking a cad file make sure you insert it with the correct import units (measure it before in the cad file) and the positioning is Auto - origin to origin or Auto - center to center. You can check out your current view settings (shortcut VV) if your imported categories (means cad files) are visible.
You can find an overview of the link settings here: https://knowledge.autodesk.com/support/revit-products/downloads/caas/CloudHelp/cloudhelp/2016/ENU/Re...
Beste Grüße
Björn
Senior BiM Consultant bei
www.bimotion.de
E-Mail | LinkedIn | YouTube
in reply to: bjoern_teutriene
In addition to bjoern's post, make sure that the linked CAD file is set to the right elevation. Easiest way to see this is when in 3D view, click on the linked CAD file and adjust the elevation to have it displayed on your sheets.
A_MAQ
thanks for your reply
does not work
i have a imported cad
not visible in any view even if in 3d view
bjoern_teutriene
in reply to: A_MAQ
In that case I would like you to purge your Revit project, zip it together with your CAD file and upload it here.
Beste Grüße
Björn
www.bimotion.de
