Uncommon RC Beam Annotation. Help
In forming structural framing plan, beam was annotated by default setting, i.e. with type name (width x depth mm) How can I alter this format and change it to (depth x width mm)?
shefypattambi
hi @Anonymous,
open your beam tag family and select the label and edit the label; from there just  move "depth" parameter on top of "width" parameter.
if you are still confused just upload your tag family  I will do it for you.
