Change the Beams y justification
Hi everyone,
I have started a beam family and i customize it for my case, the issue that i am facing i want to be able to control the y justification point for right and left. check the picture below.
Your help is appreciated.
Regards
Nawar
shefypattambi
Hi @Anonymous,
could you please upload your beam family to have a look at it ?
It's a simple case but represent my situation
https://we.tl/t-v1g5SBkl9O
shefypattambi
Hi @Anonymous,
I could not find any issue in your family, did you try with "y justification" "y offset" parameter ?
Hi @shefypattambi
According to your answer i can edit the line using the y offset and the y justification auto detecting for the edge and can't be changed for the element ?
shefypattambi
Hi @Anonymous,
This two reference planes define the center and origin of your beam. you can uncheck the define origin box and place another strong reference plane as your origin and adjust your geometry according your requirements.
