Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Turn off perpendicular rebars to the view
6 REPLIES 6
jroa3ZD27
663 Views, 6 Replies
Hello everyone, I need to ask if there's a way to turn off all rebar elements that are perpendicular to a view. We need to see only the elements that are parallels  (horizontal or vertical) to the current plane layout. Thanks in advance!
6 REPLIES 6
jroa3ZD27
in reply to: jroa3ZD27
thanks in advance! @ovidiu_paunescu
ovidiu_paunescu
Hi @jroa3ZD27
I think you could do that only by manually hiding those bars in that view OR by using filters, but again based on a manually assigned parameter value.
The parameter by which the bars are filtered would have to apply for that view only.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
hmunsell
in reply to: ovidiu_paunescu
@ovidiu_paunescu i was thinking the exact same thing.... Manually.
@jroa3ZD27  You could try putting them on different worksets. you'd have to come up with a naming convention that worked for  you. you could the parallel one on one workset and the perpendicular ones on another workset. then turn the ones off you don't want in your view.
Howard Munsell
awes
With https://www.sofistik.de/documentation/2020/en/reinforcement_detailing/cmdref/tag/detail_layer.html you can add layer parameter and then apply a view filter.
Ahmed_Muharram
you can assign a partition and hide it using filters in visibility/Graphic options
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
jroa3ZD27
Thanks everyone for your help; I accepted the sofistik solution because is the 'less manual' option to achieve that we want on a large project, and we are working on that.
Thanks again
Jorge
