Trying to create a gable wall end connection in Revit 2023
walidel
walidel
Hello, I'm trying to create a Gable wall end connection in Revit but Revit seems to give an alternative that doesn't fit my design intent. See I can easily create it in Advance Steel. But When I try to reproduce the same connection in Revit I got a different design. I changed the order of connected elements but still the same. I thought it was also due to a selection order like in Advance Steel, but no. What is wrong with my process?  See picsThis is the connection I created in Advance Steel 2023This is the connection I created in Advance Steel 2023This is the connection Revit 2023 givesThis is the connection Revit 2023 gives
robertwmerriman1
Not at my machine but it looks like the difference is the bolts going through both flanges in Revit
In the parameters for the connection go to either the horizontal or vertical bolts and untick "Bolts on guage lines" then change the centers to something more sensible and the bolts should drop to the bottom flange as shown in the Revit model
Rob Merriman, AEC Technical Lead, Graitec
walidel
It worked out perfectly Sir. Many thanks
