transferring dwg/dxf export setup information
janiceh
janiceh
I have finally had time to spend to get the DWG/DXF export settings changed to make the exported drawing look like one our office would create.  Thereby reducing any time with minor adjustments to layers and linetypes to be able to work with the drawings in our standards.  Is there some way to export the settings I just created into a file to be read by other versions of Revit.  It would make it easier to transfer to other users and allow us to import these settings into later versions of Revit and save time where we won't have to re-create the wheel in each version of Revit.  Any ideas would be helpful, and if this is not available in Revit perhaps it could be added in future versions.
Thanks for all your help and suggestions.
sureshchotrani
Can do via Transfer project standards, see screencast:)
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
sureshchotrani
In this I am selecting correct dwg/dxf set up
mqueiroz
It doesn't solve the problem. I also would like to use the [dwg/dxf export setup setting] in Revit previous version and it's not possible to transfer project standards between different versions...
dmarchant
Just make a copy or open/upgrade but don't save.
This is transferring between Revit 2020 and 2022 as a test, worked fine, you need your export settings saved and named for it to be seen as an option to transfer.
