Revit to Robot
Revit to Robot
Revit to Robot
I am trying to import a Revit file to Robot.
In Robot beam and column caacteristics are unknown, and slabs disappears (only the one with a load on it appears)
Is there anything wrong I am doing?
Thank you.
okapawal
Check material assigned to the structural elements.  Default materials assigned as <By Category> in the structural template have no physical properties.
Choose a concrete material with phisycal asset.
Waldemar Okapa
Sr Product Owner
Hi, thank you for your reply.
As you can see in the attached picture, concrete material is assigned to the slab. Is there nother pameter I need to change?
Thank you.
Rafal.Gaweda
Autodesk Support
Autodesk Support
The slab ar any object you want to transfer from RVT to Robot has to be structural with analytical model
Rafal Gaweda
