Rebar image location
sureshchotrani
Advisor Advisor
Message 1 of 11
sureshchotrani
Does anybody know where images are saved for rebar shapes, which we are able to see in Revit project file.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Replies (10)
Message 2 of 11
erik_snell
These are not saved images. They are drawn base on the rebar shape definition. You can edit the shape definition in the family editor.
Autodesk Logo
Erik Snell, P.E.
Experience Design Architect
Autodesk Revit
I am an Autodesk employee and the opinions or commentary I provide are my own and not necessarily that of Autodesk, Inc.
Message 3 of 11
sureshchotrani
I was actually looking for images to insert in schedule:(
Message 4 of 11
Yes Suresh I am looking for a easy solution .For now I'm manually doing all the stuff
Message 5 of 11
1368026189
HI ,thanks for your reply here.it would be great if you answer my question around this topic .
https://forums.autodesk.com/t5/revit-api-forum/rebar-shape-info-rebar-label/td-p/7510370
Message 6 of 11
shefypattambi
Hii @sureshchotrani @Anonymous,
Please read this post. it will help you
Rebar Shape image
Message 7 of 11
-FDC-
You can do that in the shape definition.
Edit the rebar family and insert the image at the line "shape image"
Reload the rebar
Then add that parameter to your shedule.
Message 8 of 11
1368026189
Hi shefypattambi:
 thanks for your reply, so how i can get the image from the family via revit api? the .png and .rfa files I download from the post  are quite beautiful but I can not use it directly.Smiley Sad  who made the png and how he made it? I wander to know HOW.
many thanks!
Message 9 of 11
-FDC-
I use my old bending shedule in autocad for this.
Message 10 of 11
shefypattambi
Hi @1368026189,
I am sorry, My knowledge in Revit API is limited. I would like to recommended you to raise this question on revit API forum. Also I would like to know why you can not use it directly ?
I believe it was created by Dieter Vermeulen from AutodeskSmiley Happy
Message 11 of 11
1368026189
Thanks a lot ,Shefypattambi!
