Timber structure
Timber structure
ecesuzenn
Timber structure
ecesuzenn
Community Visitor
Community Visitor
Hi all. I need to create a wall, timber structure  and It has a layer of insulation between timber studs, how can I create this?
I used agacad to creat timber structure, but I couldnt figure out how I can add insulation between studs.
PSmart17
A possibility would be to use a curtain wall with the vertical and horizontal mullions being your timber and the curtain panel being the insulation, or no panel at door/window openings.  Alternatively, if you want to use the timber structure you have already created then I would probably just create a generic mass family (face based would be good here) to place in the gaps to act as the insulation.
Ahmed_Muharram
check this video https://youtu.be/NtZCEM4Gmvc
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
