Central file problem
anna_palina_kristjansdottir
Hello
I have a weird central file problem, when I open the file some steel structures are not visible on sheets, but when I open the file and detach the central file then it's visible. When others open the central file everything is fine and everything is visible.
I have tried to make a new central file but the same thing happens when I close the file and open it again. I have also tried audit and restarting the computer.
Ahmed_Muharram
try repairing the central file https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Revit-C....
try troubleshooting the visibility options https://youtu.be/LUH-HgUyYUQ
lastly it might be a hardware issue check the driver of the VGA and other computers configurations
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Make sure you open all worksets.
ennujozlagam
try to update your graphics card driver to the latest and see if helps.
