Ability to modify the automatic 4ft "Adjusted [view] Range" for floors.
Please add a feature to allow the user to specify or remove the 4ft "Adjusted Range" of floors (and stairs and ramps).
Revit displays floors, stairs, and ramps on a view if they are within 4ft of the bottom of the primary view range (regardless of the view depth). If the floor is within the view depth, then it will display as a "beyond" line style (which is a global setting and will affect other views when adjusted) and, if the floor is below the view depth and within 4ft (which is an automatic "Adjusted Range" for floors) of the bottom view it will still be displayed with the projection lines for its category. Refer to https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Revit-D... for additional information on this. The only way to remove these floors from view is to hide them. Please add an option to remove/modify the automatic "Adjusted Range" or remove this feature.
Thank you.
