The table does not correctly count the bar length.
aNGUloperry
Observer Observer
aNGUloperry
Observer
Observer
I was trying to create a steel schedule, and the table generated by Revit does not show the correct value for the rebar length. I searched and it seems to be a ‘K’ value that I cannot modify; it is a default value and for some reason, it is not counted in the schedule table. How can I correct this error?
Tom_Kunsman
Can you post a screen shot of your schedule? So hard to determine what is wrong without that or the model
aNGUloperry
Observer
Observer
Thanks for your answer, Tom! Sure, here it is.
The thing is, if you do the hand calculations (2*0.4 + 2*0.9 + 2*0.1 = 2.8m) and the schedule shows in all cases -6, -5, -8 cm, this affects the weight results obtained in the table and the real bar length
Reviewing the parameters, there is a "k" value, that I think is manipulating the Schedule result.
Thanks a lot for Ur help!
aNGUloperry
Observer
Observer
I apologize, is a "H" value, not "K".
awes
Please note the bending radius of the rebar.
jay_colcombe
as @awes
Jay Colcombe
Autodesk Certified Instructor
