text generator
text generator
christophJYCQU
Message 1 of 11
text generator
christophJYCQU
I am trying to use the text generator tool in my extentions tab, but it will not open selected word files. I get errors when I try. Any idea what's going wrong? I've tried .docx and .doc files, neither will open.
Replies (10)
Message 2 of 11
christophJYCQU
this is a cut and paste of the error when trying a .doc file
REX:
Engine version: 2016; Version name: ; Culture info: en-US
PLATFORM:
Win32NT Microsoft Windows NT 6.2.9200.0
SOURCE:
AREX
MESSAGE: (3/23/2016 1:57:39 PM)
Unhandled exception.
Assembly name: DRevitTextGenerator: The process cannot access the file 'C:\Users\christoph\AppData\Local\Temp\DTextGen\doc.txt' because it is being used by another process.; StackTrace:    at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
   at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy)
   at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
   at System.Windows.Forms.RichTextBox.LoadFile(String path, RichTextBoxStreamType fileType)
   at REX.DRevitTextGenerator.Resources.Dialogs.ControlMain.button_path_Click(Object sender, EventArgs e)
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
DEPENDENCY: Autodesk.REX.Framework, Version=2015.0.0.0, Culture=neutral, PublicKeyToken=51e16e3b26b42eda (file version: 2015.0.0.3253) | REX.Controls, Version=2016.0.0.3511, Culture=neutral, PublicKeyToken=null (file version: 2016.0.0.3511) | REX.Controls.WPF, Version=2016.0.0.3511, Culture=neutral, PublicKeyToken=null (file version: 2016.0.0.3511) | REX.Controls.Forms, Version=2016.0.0.3511, Culture=neutral, PublicKeyToken=null (file version: 2016.0.0.3511) | REX.Mathematics, Version=2016.0.0.3511, Culture=neutral, PublicKeyToken=null (file version: 2016.0.0.3511) | REX.Preferences, Version=2016.0.0.3511, Culture=neutral, PublicKeyToken=null (file version: 2016.0.0.3511) | REX.System, Version=2016.0.0.3511, Culture=neutral, PublicKeyToken=null (file version: 2016.0.0.3511) | REX.Service, Version=2016.0.0.3511, Culture=neutral, PublicKeyToken=null (file version: 2016.0.0.3511)
LAST ENTRIES: 4 / 17
16: (3/23/2016 1:36:39 PM)
AREX.Engine - Unhandled exception.
15: (3/23/2016 1:33:09 PM)
14: (3/23/2016 11:27:58 AM)
13: (3/23/2016 11:27:51 AM)
Message 3 of 11
JasonLLINDNER
the error says contact Extension Developer...I don't think you can reach them here
Message 4 of 11
christophJYCQU
Why not? Is it not made by auto desk?
*Text Generator for Autodesk Revit 2016*
*© 2015 Autodesk, Inc. All rights reserved. *
*All use of this Software is subject to the terms and conditions of the
Autodesk license agreement accepted upon installation of this Software
and/or packaged with the Software.*
*Trademarks*
Autodesk, Revit are registered trademarks or trademarks of Autodesk, Inc.,
and/or its subsidiaries and/or affiliates.
All other brand names, product names or trademarks belong to their
respective holders
Christoph Knerr
christoph@heatlyengrs.com
505 433 8733
120 Vassar Dr. SE Suite 200
Albuquerque, NM 87106
Message 5 of 11
RDAOU
@christophJYCQU
😄 probably he meant to address Autodesk directly (I am assuming you have a subscription and not a student account) and this is more of a user forum than Autodesk Support.
I personally have never used this extension...sorry can't help
Message 6 of 11
I think the best text generator is weird text on fontvilla. This is a very good text generator.
Message 7 of 11
akhtarm7443
Community Visitor
Community Visitor
How did you resolve this issue? I am facing the same issue with my fonts for ig extension. When I was searching for this issue on Google, I came across a link to your post.
Message 8 of 11
jay_colcombe
I have seen this where an update to Revit has been applied and the Addin is out of Sync with the Revit Version.
check your Revit Version and then compare on the Addin Developers website to ensure you are using the latest compatible release.
Jay Colcombe
Autodesk Certified Instructor
Message 9 of 11
akhtarm7443
Community Visitor
Community Visitor
The conversor de letras bonitas is amazing for adding a stylish touch to your texts! Perfect for social media, messages, or anything you want to stand out.  Try it out and get creative!
Message 10 of 11
petobi7665
Community Visitor
Community Visitor
The issue might be that the extension doesn’t support .doc or .docx files directly. Try converting the Word file to a .txt format and then loading it. Also, make sure the file isn’t corrupted and that your browser and the Brat generator extension have permission to access local files.
Message 11 of 11
conversordeletras_site
Community Visitor
Community Visitor
Spice up your words! The conversor de letras is your go-to for transforming plain text into eye-catching styles. Make your messages, bios, and posts truly unique.
