Sub-Connection Category Visibility
z.zecevic
z.zecevic
is there any possibility here to control the visibility of the Sub-Connection Category (see pic attached).
I am having the struggle to hide those by element for every single view. Otherwise those elements are causing difficulties in handling the setting of views into the sheets.
I´ve read an workaround somewhere, where one can set those elements on a separate workset (collabo mode), and then make this workset not visible projectwise.
That is not a solution for me because the colab is not necessary in my case.
Greetings
Jamhmer_Oc
Hi @z.zecevic
It is true that the visibility of the graphics cannot be hidden, an alternative to hiding it is through the phases, see attached file.
Jamhmer Oc
z.zecevic
Thanks @Jamhmer_Oc,
that is a cool hint. It´ll solve my problem for now.
Than on the other hand I will need to reorganise all of my phases wich I used to define site excavations, precast delivery study cases etc.
It would be nice if @Anonymous  would incorporate the steel connection tools or any other new tool in the usual revit workflow (regarding visibility options).
I´ll mark it as solved, allthough a workaround button would also be a nice option in this forum.
Thanks again 😉
jiya_ji
Thank you for your reply ... I was having same problem ...  I think i can solve it now
