Attach stair stringer to landing stringer
Hi everyone,
I am looking for a way to attach the stringer from the stair to the landing stringer. Just like in the green circle. Is there any way to do this? The stair on the right side is made by mirroring the stair on the left. The parameters are identical.
Thanks in advance
BDMackey
It looks as though they are two different stairs so that isn't possible.  However you can accomplish this with a single stair.  When starting a run, change the properties to see the run not the stair assembly, then you can change the "Relative Base Height" for the run to match the landing height, then start the run at the inside edge of the stringer.  This can be done for many different runs off the same landing.
@BDMackey ,
Thanks for your reply.
The stairs should be identical, as they are mirrored. Also, i can not see the specific run in the properties.
Any suggestions? I attached the revit file.
Thanks in advance
BDMackey
When you are in a command such as stairs, the properties displays the assembly itself, if you hit the properties dropdown (not the type selector) then you can see the view properties as well as other sub sets such as stair runs.
In you scenario you have converted the runs to sketches, this is probably the issue.  It is more difficult to get the stairs to join properly when the runs have been converted to sketches.  I would try remaking them with the runs not converted.
@BDMackey,
It took me a while to get the hang of it, but it's correct now. Thanks for your help
BDMackey
Glad you figured it out.
