Structural truss symbolic line in Course visability
brianvogler
Message 1 of 8
brianvogler
the structural truss family has a symbolic line that shows in course view in plan.
is there a way to modify it to show in Medium view?
[ The subject line of this post has been edited for clarity by @handjonathan Original: revit structural truss symbolic line]
Replies (7)
Message 2 of 8
jay_colc
You could set the Model Category for the Detail Level in the Visibility Graphics for that View on Trusses to be Coarse?
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 8
brianvogler
when i'm in Medium view the trusses show the member symbolic lines.
(majenta lines)
when in course view they show the stick symbol lines.
(green lines)
Message 4 of 8
jay_colc
Do you have View Filters setup or a View Template with Graphic Overrides?   As it appears the are not showing as a normal coarse/medium style in. Structural Template
Jay Colcombe
Message 5 of 8
brianvogler
we have modified the dimension lumber family symbolic line  to appear as centerline to match our office standard in medium view.
I'm trying to get the structural truss family "stick symbols" line to appear as a centerline in the medium view
Message 6 of 8
brianvogler
i got it to work finally.
for some reason when i switched to course view it was not changing.  i had to restart revit (2025)
i then created a duplicate dimension lumber family to use in my truss family that does not have a symbolic line that appears in medium view.
Thanks your for your help
Message 7 of 8
jay_colc
I am a little confused as you wanted to have a symbolic line in medium detail level but created a new dimension lumber which doesn’t have a symbolic line?
However I am glad you got it sorted as you just needed to find the purple override in Object Styles and change this!
Jay Colcombe
Message 8 of 8
brianvogler
correct.  the structural truss family has a stick symbol within the family that even with no other family members included will show up on coarse view.  so i needed a truss that would have members showing the actual member in 3D views, in plan views i needed the dimension lumber family members to show as dashed lines along with the truss family in plan view showing as it appears in course view.  so my truss family structural members could not have a symbolic line.  yes......very confusing  .  your advice on having the truss family appear in course detail view in plan was very helpful.  I was missing that one .
