How to create structural column from mullion at the same coordinate both top and bottom of column, as a slanted colum.
walidinJKACC
walidinJKACC
Here i need help how to create structural column from architectural mullion at same coordinate both top and bottom of column as a slanted colum?
While i try to create structural column from 3d view, 3d snap won't work. And i can't do with model line as help (reference line) when i pick curtain grid.
I attach image and revit file v2024
this is the architectural drawing:
Create structural framing, not column, use pick line and tick 3D snapping box, then pick and edge of the mullion.  Actually, don't pick mullion, pick the mass divided surface line.
antoniocaeiro
Good evening, explore this approach.
handjonathan
Hi @walidinJKACC
Thanks a lot for posting your question to the forums!   Has the solution suggested by @ToanDN @antoniocaeiro helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
walidinJKACC
thank you @ToanDN and sorry for late reply
walidinJKACC
thank you @antoniocaeiro . Im sorry for late reply
