Structural Precast Extension for Revit How it works ?
Mikael_QUIJADA
Mentor Mentor
Message 1 of 25
Mikael_QUIJADA
Hi 🙂
Can anybody explain me how Structural Precast Extension for Revit works ?
For exemple I did not succeed to draw an hollowcore slab or créate a shop drawing 😕
Thank a lot !
Mikaël QUIJADA
Expert Revit Structure
Replies (24)
Message 2 of 25
teodorb
Hi Mikael,
Did you use the precast templates or started from a template of your own? If you start from an empty template you should first initiate Configuration to load all the families needed for our add-on, make all necessary adjustment and after that press okay command. Pressing the Okay command is very important, because otherwise the loading of families will be done once again until you acknowledged the loading by pressing the Okay button.
The precast add-on work only with structural elements (e.g. structural walls, structural floors);
By using the Ssplit command you will obtain precast assemblies which can be afterward reinforced using the Reinforcement command.
At the end of Split or Reinforcement command you will be able to use the shop drawing command.
You can also create manual assemblies to use the shop drawing command. The main requirement is that inside the assembly the part is included in the assembly,
Additional information can be found here: http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-3AA696FA-8CE6-43CC-AB60-D0BC305351EC
Let me know if you need additional information.
Kind regards,
Bogdan Teodorescu
Bogdan Teodorescu
Product Owner
Message 3 of 25
teodorb
Hi Mikael,
By using the Split command you will obtain precast assemblies which can be afterward reinforced using the Reinforcement command.
Kind regards,
Bogdan Teodorescu
Bogdan Teodorescu
Product Owner
Message 4 of 25
Rivera-Artes
Hi, I tried to download the new precast extension and it said is for subscription only, I am already under subscription but the option to download the application is not available.
William Rivera,
BIM Manager
Silman
Message 5 of 25
TomislavGolubovic
Did you log in as yourself on the App Store?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Message 6 of 25
Mikael_QUIJADA
Thanks 🙂 It's works perfectly
Mikaël QUIJADA
Message 7 of 25
peticid
Dear Rivera,
I am delighted to share with you that the Structural Precast for Revit app is now available to Maintenance plans customers, Single-user and Multi-user subscriptions customers of the following products, suites and collections: Autodesk Revit, Architecture Engineering Construction Collection, Autodesk Structural Fabrication Suite, Autodesk MEP Fabrication Suite, Autodesk Building Design Suite Ultimate, Autodesk Building Design Suite Premium, Autodesk Infrastructure Design Suite Ultimate, Autodesk Infrastructure Design Suite Premium.
I hope you will enjoy our new product and I am looking forward to knowing your impressions around it.
Kind regards,
Dan Peticila, M.Sc. Str. Eng.
Product Manager | Autodesk Revit
Message 8 of 25
Hello Sir,
I want to create my own view in structural precast element. Currently it is showing side view from X direction. I want to get one more side view from -X direction. How can I do it? I tried to change  viewport.rfa but couldn't save it. Then I renamed file  as viewport2.rfa. This time it generated drawing sheet but it was blank.
Message 9 of 25
teodorb
Dear @Anonymous,
Go to the your titleblock (it should be located here C:\ProgramData\Autodesk\Structural Precast for Revit 2018\Families\en\Title Blocks). Open the title-block you will be using in the configuration menu, select the sideview and copy it where you need it. Select the copy and in the properties palette, under viewing direction, type '-X'.
Kind regards,
Bogdan Teodorescu
Product Owner
Message 10 of 25
I followed your way before posting on forum. I tried one more time after your reply. But look as the screen-shot. It is generating identical side views for +X and -X which shouldn't be in this case.
Message 11 of 25
teodorb
Hi @Anonymous,
Could you please add to your assembly a mounting part on one of the front/back face of the wall. Afterward, use the mounting parts command to add the mounting part into the assembly, and recreate the shop drawing. There you will see that the view are created accordingly.
Kind regards,
Bogdan Teodorescu
Product Owner
Message 12 of 25
Can I overwrite Viewport.rfa and Schedule.rfa? I want to get material schedule like this :- Capture.JPG
Currently precast add-in is not showing description (i.e. third column). I opened Schedule.rfa and I would also like to know (if you can give some links or video tutorials) how to write formulas in family type window and how to make custom lookup tables for precast add-in.
Message 13 of 25
teodorb
Hi @Anonymous,
All the schedule are found in Schedule Templates.rte. Here you can define and change any template according to your needs. If you also want description, you just need to add this in the schedule template you want to use.
Here is a link on how to use formulas: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
Gere is a link on how to manage lookup tables: https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/RevitLT-Customize/fil...
Kind regards,
Bogdan Teodorescu
Product Owner
Message 14 of 25
Rab_i
I ran into a problem using Structural Precast Extension for Revit. It impeded with Generic Models I was trying to update fields for. I am attaching few snippet from the Journal in the hope the development team will look into it.
The behavior was, I tried to change parameters in my Generic model family and it wouldn't change. I noticed the lines after the selection command was completed. The Generic model has structural framing family nested.
After I uninstalled the extension the family behavior was restored to normal.
 Jrn.Grid "Control; FormView , Properties , IDD_PROPERTIES_PALETTE; IDC_SYMBOL_GRID" _
         , "Selection" , ""
 'E 15-Feb-2018 12:35:15.491;   0:<
         , "MoveCurrentCell" , "  Jamb Type Name" , "ValueCol"
' 1:< SLOG $7f28debb 2018-02-15 12:35:16.695 .LockUsers  R locked
' 0:< SLOG $7f28debb 2018-02-15 12:35:16.706 >Auto
' 3:< EP::readDeltas 21380 -- no deltas
' 4:< syncEPtoDisk stats: 0 misses / 0 hits = NaN ratio
' 4:< start logDiffEP of only CENTRAL_BORROWS
' 4:< stop logDiffEP of only CENTRAL_BORROWS
' 3:< SLOG $7f28debb 2018-02-15 12:35:16.717 .Auto:LockUsers  R unlocked
' 2:< >ER::dumpCache 0 OLD versus 0 NEW
' 2:< <ER::dumpCache
' 0:< SLOG $7f28debb 2018-02-15 12:35:16.727 <Auto
 'E 15-Feb-2018 12:35:17.096;   0:<
         , "PartialEdit" , "  Jamb Type Name" , "ValueCol" , "101358158" , "9" , "9"
 ' 0:< Unnecessary nesting;ElemGrid_1;-1;IDS_MODIFY_TYPE_ATTRIB ;N++EB(NB);
 'H 15-Feb-2018 12:35:17.127;   1:<
 Jrn.Data "Transaction Successful"  _
         , "Modify type attributes"
'H 15-Feb-2018 12:35:17.210;   0:<
Jrn.Directive "IdleTimeTaskSymbol"  _
        , "5.PostCommandTask"
'H 15-Feb-2018 12:35:17.227;   0:<
Jrn.Directive "IdleTimeTaskInvocation"  _
        , "5.PostCommandTask", 0, "{}"
 'E 15-Feb-2018 12:35:17.228;   0:<
 Jrn.RibbonEvent "Execute external command:CustomCtrl_%panelHelp%About:Adsk.RPCA.Commands.CmdShowAboutBox"
' 1:< API_SUCCESS { Registering FailuresProcessing event by application Revit Precast (3c028904-e50f-4a8c-b059-098de92d92fc). }
' 1:< API_SUCCESS { Unregistering FailuresProcessing event by application Revit Precast (3c028904-e50f-4a8c-b059-098de92d92fc). }
' 4:< MP_MOVE: Difference because of preferring view norm
' 0:< MP_MOVE: Difference because of preferring view norm
'H 15-Feb-2018 12:35:17.350;   0:<
        , "5.PostCommandTask", 0, "end"
' 0:< <<Begin update Provider-triggered panels>>
Please contact me if further details needed. Thank you!
Message 15 of 25
Hi, I had this issue, it needs you to split the slab, make sure the slab is the sam depth as the hollow core ie 200mm  when it has split do not un click ie make sure you dont de selrct it, then go to drawings it worked this way ,, hope it helps  you
kevin
@Mikael_QUIJADAwrote:
Hi 🙂
Thank a lot !
Message 16 of 25
teodorb
Hi @Rab_i,
Another user has added this here: https://forums.autodesk.com/t5/revit-ideas/structural-precast-update/idc-p/7920512#M19619
You can add the relevant details inside this idea.
Kind regards,
Bogdan Teodorescu
Product Owner
Message 17 of 25
lzhhpeng
Observer
Observer
When I use the tool to split floor, the floor always been split horizontal.
How can I split the floor vertically?
Thanks.
Message 18 of 25
teodorb
Hi @lzhhpeng,
In order to have the segmentation on the other direction you need to change the spanning direction of the floor. Select the floor to edit the boundary and change the spanning direction on the other way.
Kind regards,
Bogdan Teodorescu
Product Owner
Message 19 of 25
lzhhpeng
Observer
Observer
Hi, Teodorb
Thank you for reply, now I know it.
Maybe you have a forum for precast extension, I have lots of questions.
Can I use shop drawing function in the extension for my precast stair? It's generic model. I create part and assembly for it, but when I try to generate shop drawing an error come up.error.png
It will be long time before I can make it work for me, but I believe it's worth to try.
Thank you for help.
Harry
Message 20 of 25
lzhhpeng
Observer
Observer
Another question for you, Teodorb.
Schedule Templates.rte, this file is read only on my computer. Do you think I can save it as a different file and let Revit use my file? - Thanks.
