Will Revit 2018 have the 3D pdf feature? Is there a way I can download the feature? When will Autodesk allow Revit users to save down to earlier versions? My team relies on the 3D pdf viewer as our job progresses. Please tell me I can download the add-on to Revit 2018.
Does not seem to be part of Revit soon. See THIS idea with response from Autodesk (support the idea to get it higher up the agenda).
There are several add-ins (not used them myself) in the app-store. Also bluebeam seems to be a solution used by different people.
Revit has never been backwards compatible. As this will cause a lot of overhead in the development process I do not see this happening. Especially now, when the software goes more and more to a subscription license.
Louis
Please mention Revit version, especially when uploading Revit files.
You just need to add Revit 2018 in your Bluebeam settings. It is most likely not listed and you need to select it manually. If it is not listed you need to update your Bluebeam installation. (happened to me with Revit 2017)
So, apparently Bluebeam has not created a plugin for Revit 2018, and hopefully it will be created in the near future. Thank you all for the responses.
This is pretty much Standard Operating Procedure for many Revit Add-Ins.
Bluebeam specially seems to lag about 6 months with their Add-In.
A while ago, I heard that the Bluebeam (2017) Add-In for Revit 2018 would be out in August. Which is quickly coming to a close.
