I have a small elevator addition project, we laid out the concrete walls really quickly (3 of them) and placed a wall foundation (strip footing) under them. As we progressed with the project, we added another concrete wall, and every time I go to place the foundation under it, it cuts the existing footing back. Please see attached pictures, and if anyone can help me that would be great.
Solved by Jamhmer_Oc. Go to Solution.
I tried no problem. Can you upload a TEST file for review?
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
I removed the existing building, so it it is all just the new construction.
I deleted the wall shown in the picture, copied the front wall, there may be a software problem. I am using Revit 2021.
Arman Margaryan
Hi @Jason.P
The correct way is to separate the walls.
Select the wall, at both ends you will find a circle, press right click on it and separate; as shown for both ends.
Then you align with the face of the other wall so that it is well modeled, now you only place the foundation.
Jamhmer Oc
