attach cloumn
attach cloumn
omarx1989
Message 1 of 14
attach cloumn
omarx1989
Replies (13)
Message 2 of 14
ArmanMargaryan
What is the problem?
I didn't understand the question well, please detail.
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
Message 3 of 14
omarx1989
how to attach column to isolated foundation?
note: isolated foundation not in same level.
Message 4 of 14
ArmanMargaryan
Can you upload the file so we can show you how to do it?
Arman Margaryan
Linkedin | Facebook
Message 5 of 14
Jamhmer_Oc
Hi @omarx1989
I hope it helps you.
Jamhmer Oc
Message 6 of 14
ennujozlagam
you wrote :
attach column ( one click )
how I can do that ?
No, you can do that on an individual basis because your base levels are different.
Message 7 of 14
omarx1989
one by one !!!!
it takes too much time if i do that in all columns in project
Message 8 of 14
omarx1989
its no any tool or update to do that ??
select all columns THEN select all isolated foundation.
Message 9 of 14
omarx1989
Message 10 of 14
ennujozlagam
no other way, Revit has also limitations, accept the reality?
Message 11 of 14
ennujozlagam
you can try something like this , create a levels (just copy levels for your reference only ) where do you want to attach your column base levels and see if helps .thanks
you can also hide the copy levels created in view, if you don't to see them.
Message 12 of 14
omarx1989
@ennujozlagam
thank you for you help
 can Autodesk make tool or update "Attach column" command to do the following :
1- select all columns
2- then select the "Top of PC" Level
3- then columns automatically extended to the "top of pc level" without takes isolated footing down.
Message 13 of 14
ennujozlagam
Post this to IDEAS board. As I have said before Revit also has own limitations. We are trying to suggest a solution with your issue, but you still not satisfied. Sorry I can't' help much.
Message 14 of 14
If it helped you, mark the answer to help other users.
