Message 1 of 14
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
What is the problem?
I didn't understand the question well, please detail.
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Can you upload the file so we can show you how to do it?
Arman Margaryan
you wrote :
attach column ( one click )
how I can do that ?
No, you can do that on an individual basis because your base levels are different.
its no any tool or update to do that ??
select all columns THEN select all isolated foundation.
no other way, Revit has also limitations, accept the reality?
you can try something like this , create a levels (just copy levels for your reference only ) where do you want to attach your column base levels and see if helps .thanks
you can also hide the copy levels created in view, if you don't to see them.
thank you for you help
can Autodesk make tool or update "Attach column" command to do the following :
1- select all columns
2- then select the "Top of PC" Level
3- then columns automatically extended to the "top of pc level" without takes isolated footing down.
Post this to IDEAS board. As I have said before Revit also has own limitations. We are trying to suggest a solution with your issue, but you still not satisfied. Sorry I can't' help much.
If it helped you, mark the answer to help other users.
