family creation
family creation
family creation
Which are the available materials for material selection when creating a new family? Is there any section the make it new family with sepical meterial ? Can I change the material after I load it into the project? What alternative command is there for the Fillet command (when family creation)?
hmunsell
  • it depends on the family template you select. different templates may have different materials loaded into them. typically most templates only have "Default" materials loaded.
  • materials can be created or loaded into a family at any time. in my case i have edited the templates i use at my office to have the typical materials i need.
  • you can assign the material parameter to a Instance or Type parameter to allow you to allow you to change material after it has been placed.
  • the fillet command should be available in a family when placing linework. alternatively you could use the Trim(TR) command to extend two lines to intersect each other.
Howard Munsell
hmunsell
sorry I couldn't be more detailed earlier, i was in a meeting :-).
https://autode.sk/2LB0IWr
see also....
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN...
Howard Munsell
