Structural Foundation not in the schedule
adimariaBXE2A
Message 1 of 9
adimariaBXE2A
Hi, I am working on a structural model where I have structural foundation slabs.
I created a multicategory schedule to show Family, Type and Material:Volume as field, but the foundations are not listed (the schedule is empty). All other structural element e.g ground beams and foundation walls are listed.
Replies (8)
Message 2 of 9
Ahmed_Muharram
how do use sorting?
I recommend you use material take off instead
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Message 3 of 9
semi
Probably due to a wrong filter, you might want to check your phasing, category,...
Message 4 of 9
adimariaBXE2A
Hi thanks for the answer. There is not filter applied or any sort of phasing
Message 5 of 9
adimariaBXE2A
Hi, there is no sorting or filter applied. I have used a multicategory schedule including all the category and yes I have used material takeoff.
Message 6 of 9
semi
Can you share the file?
Message 7 of 9
adimariaBXE2A
I detached the file from the central model. The foundation slabs are all the element highlighted in the image.
You can find the multicategory schedule for material take-off I created.
Thanks for your support
Angelo
Message 8 of 9
semi
Well, trying to schedule a material offset of geometry without a material is asking for a beer in a winebar:
As soon as I put in a material this happened:
Message 9 of 9
adimariaBXE2A
Hi @semi
that seems to be a common sense 😄 However, I never thought it could be something related to material as I imported the family from the Revit default folders and would have expected the material to be already assigned (by category as any other object).
That solved the problem, and now I can have my volume in the schedule 🙂 🙂 🙂
