Reinforcement changes automatically
dipoanggi.sd
dipoanggi.sd
Hello, i have problem about rebar, My reinforcement can change automatically when I do other work, such as drawing other reinforcement or creating new objects such as new plates or beams, the size, shape or placement can change automatically, for note I am already using the latest revit at the moment. Thanks for the help.
ovidiu_paunescu
Hi @dipoanggi.sd
Rebar automatically constrains to the concrete host faces or to other rebar and reacts to changes. For example standard bars constrain to stirrups automatically (to the sides and corners). You can manually override these constraints to obtain the desired behavior for reacting to changes or for reusing the rebar in other elements.
To learn more about managing these constraints you can have a look at my classes from Autodesk University:
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
