structural column analysis line do not appear in column
i used structural template and  draw  columns and beams  in a floor plan
but in 3D view i see  only the beam structural line  but not  for column
and  in sometime  i see no analytical plan appear for some levels
hi
press VV in 3D View
then make sure that Structural Column is Marked
if helped Choose as solution
thz for reply but i tried it before but still not appear any analytical model lines green on bottom and red on top or green on left and red on right
i opened default structure template given in Project >New > structural template
but it does appear in some structural analytical template prepared by my teacher.
whats the different
Please unhide the elements then make sure the enable analytical model box is checked.anatical column.PNG
MostafaElashmawy
Make sure that you use the structural column tool.
Mostafa Elashmawy
