Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Strange question about STRUCTURAL BRACE SYMBOL~
1 REPLY 1
wang_yilin
441 Views, 1 Reply
In my revit 2016; I find a strange question about the STRUCTURAL BRACE SYMBOL;
Let's see the snap~
The most strange thing for the BRACE SYMBOL is that why the brace above symbol & brace below symbol could be shown in the Left but not right? especially for the red brace symbol in the left;
For the settings, I have already ajusted the view range setting, now they are the same in each view even though they have different basic levels.
thanks for all
1 REPLY 1
Hi Yilin,
Here are some suggestions:
  • Make sure you’re in the current build (update) of Revit 2016. If you have access, I recommend updating to “Release 2” (R2) and then Update 7 for R2   (update 8 was for C4R).  See How to tie the Build number with the Revit update.
  • Create a View Template from the view on the left and then apply that template to the other view.
  • As a test, upgrade a copy of this model to a newer release of Revit (for example, Revit 2019.1) to see if this behavior still occurs.
  • Or test in a new, simplified model using a default out of the box structural template. If it works correctly in the new model, then it could be an issue with the one existing model.
I hope that helps.
If my reply was helpful, please "Like" or click the "Accept as Solution" button below (or both).
Martin Stewart
AEC Support Specialist
