Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Steel structure
2 REPLIES 2
323 Views, 2 Replies
Steel structure
i am currently working on a steel structure on revit, 2018 version. Under the beam blue lines have appeared. How is this? and how can they be turned off?
2 REPLIES 2
Karol_Piroska
these are most likely location lines that can be turned off in visibility graphic overrides under struct framing ..
Orsolya.Balazs
Hi @Anonymous,
Please give a short feedback, if the suggestion of @Karol_Piroska clarified the situation (just marque it as accepted solution) or if you would need more help please add a bit more details.
Thank you.
Orsolya Balazs
Product Support Analyst - AEC
Autodesk, Inc.
Forma Design Contest
