Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Steel plate rounded corner export
2 REPLIES 2
GatisM
210 Views, 2 Replies
GatisM
Hello!
Tried all checkboxes. How to export steel plate shape, or how to model it correctly to be able export to ifc rounded corners?
Hello!
2 REPLIES 2
jay_colcombe
in reply to: GatisM
jay_colcombe
I assume you tried most settings so i Duplicated and Edited the Existing IFC4 Reference View (Structural) Export Setup in Revit 2023 and set the Level of Detail to High - (I don't have time to test low but though you would have used this by default anyway)
Opening the IFC back in Revit included the Filet (I created using the Steel Tab > Notch Tool)
This was also the case for Navisworks too.
Jay Colcombe
Autodesk Certified Instructor
Jay Colcombe
GatisM
in reply to: jay_colcombe
GatisM
Thanks for your replay!
Did further tests using ifc4 too. Noticed that there is no problems export rounded shapes for beams also in ifc2x3. The problem as I noticed is not with "rounded geometry", problem is with steel tab corner cut function "convex" for inner corners. See picture. I supposed to say it's Revit bug. Hope will be fixed. Ifc format must be 1:1 with rvt.
