steel connections
steel connections
omarfelipe19
steel connections
omarfelipe19
hello
I would like to know why there are no types of general bracing,
how do i add them?
johnjmbennett
There are general bracing connection types, but you need to load them into the revit software, then load them into the model space.
also you need to make sure the correct steel families are loaded from autodesk, check the various content libraries.
you should help for this with revit help, under detail steel modelling, here is a link to the AKN product help:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-S...
John Bennett
