Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Steel connections
2 REPLIES 2
460 Views, 2 Replies
Steel connections
Hello everyone!
I have a problem xith the steam connections in my program. I'm working with customized beams (thaï) and I have an error message everytime I'm trying to do a connections. I have the symbol of the connection but I don't have the representation in "Fine" mode.
Thank you all !!
2 REPLIES 2
dzanta
Have you tried to edit the family and check it's visibility settings to ensure Fine is checked?
Is the beam Shape assignment in the family set to a standard beam coming from the standard Steel Connection database?
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
in reply to: dzanta
The problem was the shape of the beam in the Medium view. My file was a REVIT 2018 that I upgraded to 2019 recently. The beams/columns section were the same for fine and medium but as my project is done I cannot create a new section for medium otherwise it changes everything in my project. So I just took off the rounding in my section and it solves my problem.
