Where can I download/install this Add ON??? It is missing in Revit 2023 - I cannot find it in the update section in
my autodesk account
Solved by johnjmbennett. Go to Solution.
in 2023 version, the addin is installed by default.
hi,
you may find that you need to install the RVT Steel library content as well to get the AS Extension to work.
https://knowledge.autodesk.com/support/revit/downloads/caas/downloads/content/autodesk-revit-2023-co...
also the Advance Steel extension for Revit is listed under the Autodesk account, as an extension in the new presentation of the account portal, filter to revit, then view details to see what is linked to revit.
then when the page changes go to extensions.
then scroll down in the list
HTH
John Bennett
Hi. I have tried to install the extension as you explained above. But I'm getting some error which I couldn't understand. Kindly Help me to resolve this issue.
Hello, I am having a similar issue as to the one you resolved above, but for Revit 2024. Can you help?
I am having the same problem as this can someone please help us resolve this issue
We also have the issue of no connections pulling through. It seems to have something to do with the SQL Local DB 2019
