Space Frame Structure
Hi all,
I have created a curved roof which has a space frame structure. In order to do this, I created a conceptual mass, divided it and used a custom pattern family to generate the space frame geometry. I then have to manually select all these lines to place CHS's which can then be exported into analysis software. Is there a quicker way to place structure on all these model lines within the roof or do I simply have to select each one manually?
Thanks in advance,
dzanta
depending on how the model lines connect and are shaped, you should be able to use the TAB key on your keyboard to select multiple Model lines prior to left mouse clicking on them.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
