Slab meshing error
Slab meshing error
Slab meshing error
I am trying to analyze my model but keep getting the following error:
"Boundary / constraining edges of object might have been incorporated incorrectly in mesh"
When I run my model of an 8 story building it doesn't generate a mesh for this single floor at all while the others seem to be ok.
How can I fix this?
ennujozlagam
it could be the interfacing? try to check show instantly and you will be directly shows where the error is. it was your add-in program detect the errors and not the revit itself. thanks
