Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Shear wall
9 REPLIES 9
Message 1 of 10
revit1980
1604 Views, 9 Replies
Shear wall
Gentlemen
What is the fastest and easiest way of creating below irregular type of concrete  shear wall in Revit
Thanks in advance
9 REPLIES 9
Message 2 of 10
A_MAQ
in reply to: revit1980
are you talking about the concrete section or the rebaring ?
Autodesk Expert Elite
Message 3 of 10
revit1980
Concrete section not rebaring
Message 4 of 10
Several ways:
1. Stacked wall with 3 wall types.
2. In place wall from a sweep.
Message 5 of 10
A_MAQ
the lower section should not be modeled as wall it should be footing if it's in foundation level or slab if it's part of slab in upper level
so the above to section can be modeled as @ToanDN said even by in place family or stack wall
Message 6 of 10
A_MAQ
here is the way
Message 7 of 10
revit1980
Thank you for your replies.really appreciated.
Message 8 of 10
A_MAQ
welcome
Message 9 of 10
ennujozlagam
@revit1980 hello, here is the screencast, another approach on how to create Shear wall. thanks
Tags (1)
Message 10 of 10
revit1980
in reply to: ennujozlagam
Thank you Mr Junne Magalzo
both screencast deserves the kudo.
Warm regards,
